Warrior with no compression...
Old Jan 21, 2001 | 09:14 PM
mlsmls's Avatar
I was out trail riding o my 97 Warrior today and it was running great but all of a sudden it just quit. I got it back home and checked for spark and there was spark, I also checked the timing chain and that was fine too. I then checked for compression and there is zero. I dont understand how I loss compression all of a sudden like that, the machine is in very good condition and it was running strong just prior to losing compression. Does anyone have any ideas, rings? valves? or maybe the headgasket? Where should I start?
Old Jan 21, 2001 | 09:42 PM
435Warrior's Avatar
Could be a broken piston ring, or it leaned out and you burnt a hole in the piston. Pull the valve covers off and see if the valves look ok from that angle. Good luck
brokemybanshee's Avatar
It actually read (0)? if so thats wacked... probally your tool is broken? You would think even without rings or a headgasket just the air from turning it over would be a couple lbs?..
Old Jan 22, 2001 | 12:07 AM
amtCHAD's Avatar
My friends did the same thing. It was his compression release on the camshaft was stuck.
Old Jan 22, 2001 | 07:59 AM
Diogenes's Avatar
Stuck compression release or stuck (as in, burned) valve will cause immediate zero compression.
Most other compression problems (rings, eroded valve faces/seats, etc.) cause LOW compression, noticed in gradual advancement over a period of time.
Diogenes
Old Jan 23, 2001 | 09:32 PM
mlsmls's Avatar
You were exactly right, it was a stuck exhaust valve. I guess I'll be off the trails for a couple of weeks till I get my head back from the shop. Thanks for everyones help.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
