2001 honda 400ex
Old May 15, 2008 | 09:55 PM
climbinlineman's Avatar
Default 2001 honda 400ex
i have an 01 honda 400 ex and i wanna change my sprockets...i know stock front is 15t sprocket and i think the rear is 38t....any1 know for sre what the rear sprocket is? if it is 15t front and 38t rear, if i change it to 14t front and 39t rear do i have to change the chain also or will my old chain work? any1's help will be greatly apperciated
Old May 16, 2008 | 02:13 AM
Sontizzle's Avatar
i think the rear is 39t stock. u can use the same chain but you may have to tighten it a little, atleast i did
Old May 16, 2008 | 10:11 AM
RancherLover's Avatar
Some one correct me if I am way off base here, but, if you are going to change the sprockets change the chain also. if you put a used chain on new teeth, or new chain on old teeth for that matter, it will prematurely wear out. Ok it might not be as bad with quads, but I put a new chain on old teeth on my cbr F4i street bike and the chain was toast in under 3k miles. This is beacuse new chain and new teeth wil wear together and it is even and constant, but you put either new chain or teeth and they wear to match the wear pattern that the component you replaced. All that equals is your new component wear out 2-5 times as fast. Hope it helps.................
Old May 16, 2008 | 10:19 AM
jrafter's Avatar
i use a 14/38 and like it alot
yea i would get a new chain to there not much more
Old May 16, 2008 | 10:36 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
You want us to tell you what size your sprocket is, when you can just walk out to the garage and count the theeth yourself????
This engine is torquey off the bottom....I went down 1 tooth in the front, and even with 22" rear wheels it was way to much! Any time I hit the throtle, the front end would stand up and salute....it got wheelie happy.
My compromise was to just go to 1 tooth bigger in the rear.
Given the age of the machine, it's a good idea to change out everything anyway....sprockets and chain.
Old May 17, 2008 | 05:35 PM
thanks for the info i will get the chain also....sounds right with what u saidi apperciate it....i'm a nub and just wanting a lil advice thank you for your help...and recon i wasn't asking for you to tell me whats on my quad i just wanted to know what the stock rear sprocket wasbut thank you too for the info
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
Asaran
Oct 8, 2015 11:14 AM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
