Rear tires toed out
I have an 04 500 HO and the rear tires are toed out on the bottom. When someone rides it you can notice it from the back when I have my fat @ss on it gets worse. I have checked for broken bolts in the rear suspenssion and found it all normal. Any thoughts?
As the suspension is pushed down the irs makes the tires bow out at the bottom like that. Just like when it's lifted they will bow at the top a little. I had a 700 sportsman and I'm here to tell ya, the stock springs suck. I recommend the progressive spring kit from highlifter. I used this kit and the squating problem was solved.
