Suzuki Lt80 won't stay running
Old May 18, 2008 | 06:38 PM
kjensen75's Avatar
Default Suzuki Lt80 won't stay running
My son has a Suzuki LT80. Lately it runs for about an hour or so fine....then it starts dieing. It'll run for 5 minutes...then dies. Usually I have to put the choke on & hit the starter a half a dozen times for it to start again. It seems to run a little longer if you just leave the choke on....maybe my imagination. And once in a while it'll stay running but just seems to lose all power....then it'll kick in again. Any ideas? Thought I'd see if it's something I can troubleshoot before taking it to a shop.
Thanks!
Old May 18, 2008 | 10:52 PM
onebigzj's Avatar
is carb clean? when running leave petcock on prime. see if the petcock is messed up. it has a pump in the petcock that works from a pulsating from the motor. but if you leave it on prime it will flow gas no matter what. after that it might turn into an ele. problem
Old May 18, 2008 | 11:45 PM
kjensen75's Avatar
Thanks for the reply.
I did leave the petcock on PRI.......it didn't seem to help at all.
Now I'm not the most mechanically inclined guy when it comes to engines (I can build you a PC or a house though!)
How would I go about cleaning the carb? Do I need to get a Chilton's/Clymer/Haynes manual for that?
Old May 27, 2008 | 03:52 PM
yagerzzz's Avatar
Check your gas cap to make sure the vent is working. It's a very simple thing to check that may save you lots of time. If it's clogged, your engine will run fine until a vacuum is created. Then it will run sporatically. When it starts running bad, unscrew the gas cap and see if it immediately fixes it.
MikeyBoyesq
Nov 27, 2020 02:44 PM
yagerzzz
Jun 24, 2015 07:45 AM
jayking232003
Jun 9, 2015 02:54 PM
Dieseltrash
Jun 1, 2015 06:53 AM
Tornado
Aug 1, 1999 12:08 AM
