07 Honda Foreman 500 Gear position flashing?
Old May 24, 2008 | 10:36 AM
RockyBear's Avatar
Default 07 Honda Foreman 500 Gear position flashing?
i'VE HAD IT FLASH 3 TIMES AND 7 WHICH WAS ANGLE SENSOR AND CDI BOX BUT NOW IT FLASHES 13 TIMES AND I'VE LOST MY MANUAL ANYONE GOT A ANSWER?
Old May 24, 2008 | 05:40 PM
wilber15's Avatar
13 is TP sensor. have you had the TP sensor harness recall done? I guess there's an updated harness for the TP sensor. You can also check the harness connection at the sensor(remove the seat and pull the plastic liner up and you'll see if on the left hand side of the throttle body). Check for water in the connectors(clean and apply dielectric grease afterwards)...
Old May 24, 2008 | 05:45 PM
wilber15's Avatar
If you need values for the sensor:
TP sensor resistance: 4-6 K Ohms
Resistance measured between Black/Red and Green/Blue at the sensor.
TP input voltage: 4.7 - 5.3 V w/ IGN on
Voltage measured between Black/Red and Green/Blue at the harness side.
TP sensor ground: check for continuity at the Green/blue wire to ground
TP sensor resistance: From full closed to full open resistance increases
From full open to full closed resistance decreases
Resistance measured between Yellow/black and green/blue terminals of sensor.
Old May 25, 2008 | 12:03 PM
RockyBear's Avatar
Yea, i've had it replaced at my dealer. I took it back up there yesterday, maybe they messed up when they replaced it, they just did it last week, thanks man
skinnyr6
Aug 25, 2023 02:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
honda71
Jul 12, 2015 05:56 AM
sara durrant
Jul 6, 2015 05:32 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
