Stuck CVs
Old May 24, 2008 | 02:01 PM
atv gooroo's Avatar
Default Stuck CVs
I went to repack my bearings the other day and had a hard time removing the front axles from the hubs. I had to beat them out with a hammer. I can useually take them out with my hands after I take the castle nut off. I took my wifes out just to see if hers were hard to get out and sure enough thay pulled right out with my hands. Any of you guys had a hard time with the axles? Any answers as to why?
Old May 24, 2008 | 03:24 PM
MECHANIKE's Avatar
Default Stuck CVs
usually when the bearings run out of grease they run ALOT hotter+ the metal distorts their stock demensions then things lock togather+ get tighter.
Old May 24, 2008 | 07:35 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Stuck CVs
thats a very good description of what happens.
Old May 24, 2008 | 08:45 PM
MECHANIKE's Avatar
Default Stuck CVs
THANX STENDORI,I TRY TO HELP............
Old May 24, 2008 | 11:04 PM
atv gooroo's Avatar
Default Stuck CVs
Sounds like a decent answer. I did get them greased and yes, they were dry. I tried to take one out today after they have been put back for a while and they still won't budge. Are they going to be like that for good? Are the splines messed up? I am just **** and would like to know. Thanks guys.
Old May 25, 2008 | 08:19 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Stuck CVs
most likely they will stay distroterd.i dont think your spines would be any problem or the hub wouldnt go back on. imo.
Old May 25, 2008 | 12:09 PM
MECHANIKE's Avatar
Default Stuck CVs
what i would do is feel the hubs as i ride,best to feel with a known greased hub,but if you feel a big diff in heat between the two i.d start looking on ebay..........
Old May 25, 2008 | 02:55 PM
atv gooroo's Avatar
Default Stuck CVs
Look on ebay for what: hubs, cvs or bearings?
Old May 25, 2008 | 04:11 PM
MECHANIKE's Avatar
Default Stuck CVs
YEAH HUBS+BEARINGS,I'VE GOT MANY SETS ON EBAY,SOMETIMES THE USED HUB WILL COME WITH DESCENT BEARINGS.............HOW HOT DO THEY GET.....
Old May 25, 2008 | 04:29 PM
atv gooroo's Avatar
Default Stuck CVs
I don't know how hot they get. I did repack the bearings to try and get a little more life out of them. I probably won't get used parts though. I saw a set of bearings for 45 dollars on ebay last week. I think that I am just going to keep my eye on things and go from there. What do you think?
