07 500 Foreman Electric Shift Problems
Old May 25, 2008 | 05:10 PM
ncbrian's Avatar
Default 07 500 Foreman Electric Shift Problems
As soon as i start the 4 wheeler the shift numbers on the display start blinking. Its blinks 3 times then pauses and then blinks 3 times again. What code is this for.
The electric shift does not work at all. Ive pulled the front fender off and checked the connectors for water and found none. Where should i look next? Shifts fine manually. Only 40 hours and out of warranty just ran out.
Old May 25, 2008 | 08:33 PM
HondaMechanic's Avatar
Code #3 is "angle sensor system" .. Did you check/clean/grease the angle sensor coupler ..
Old May 25, 2008 | 09:38 PM
ncbrian's Avatar
could you explain more about this sensor and what is actually does? Where is it located on the atv? Thanks
Old May 25, 2008 | 10:21 PM
wilber15's Avatar
I have the same wheeler as you(and also have the Honda manual for it). It's a sensor located on the lowest point of the engine right in front. Removed the side shields below your seat to gain visiual access to the engine. You will see a sensor in the very front on the bottom with an aluminum looking shield in front of it and a wiring harness coming in from the top. thats your sensor. unhook it and check for water, clean it out and put dielectric grease into the connection.
Old May 25, 2008 | 11:23 PM
skinnyr6
Aug 25, 2023 02:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
ranvette
Jul 4, 2015 06:13 PM
