2006 Hawkeye
Old May 26, 2008 | 09:18 AM
mjmmessina's Avatar
Default 2006 Hawkeye
I have a 2006 Hawkeye that has about 75 hours on it and I'm getting a squeak in the suspension. It isn't real loud but It seems to be in the front and I notice it if I sit on it or bounce the suspension. Any suggestions?
Old May 26, 2008 | 09:52 AM
TennesseeTider's Avatar
I have the same sqeak or creak. If you find the cause or a solution please post!
Old May 26, 2008 | 11:02 AM
mjmmessina's Avatar
Exactly it's a creaking sound. All of my grease fitting have been greased and I still have the sound????
Old May 26, 2008 | 11:11 AM
EastCoastWest's Avatar
Spray down your springs/shocks with some lubricant, something that wont damage the rubber seals.
Old May 26, 2008 | 12:18 PM
mjmmessina's Avatar
I tried that previously . I used some silicon spray and it's still making the noise. Any other ideas what to try?
Thanks
Old May 26, 2008 | 08:29 PM
jokout's Avatar
Well I'm afraid this is a common issue with the Hawkeye and we may just have to live with it...My wifey's Hawk has done it from day one and I thought it would work it's way out of it, but no dice.
I would guess that it is somewhere in the A-arm or control arm bushings...maybe they aren't getting enough grease from the fittings.
Old May 26, 2008 | 08:32 PM
Mine has no grease fittings up front at all.
Old May 26, 2008 | 08:52 PM
jokout's Avatar
actually your right, the 06 Hawkeyes didn't have fittings on the front a-arms, that was added in '07! Maybe removing the bushings and pivot tubes and greasing them may solve the "creak"
Old May 27, 2008 | 10:37 AM
GunnSmoke's Avatar
jokout is on the right path
i had/have the same problem. with mine it seems to be the inner bushings on the rear suspension.. each side has to bolts (upper and lower) that i take out, inside are those real good "self greased" bushings that don't work for crap... so about every 6 months i pull the bolts, bushings, pivot tubes and clean everything real good and pack in as much grease as it can take.. it gets rid of the creeking noise for a while...
Old May 27, 2008 | 07:40 PM
Rowe's Avatar
Mine did the same thing when I was riding in the mud but my squeaks were coming from the shocks. All I did was spray off with the pressure washer, and hit em with some silicone spray.
