2006 Hawkeye
Old May 27, 2008 | 08:03 PM
Hawkman300's Avatar
Default 2006 Hawkeye
well, i have 51 hours and almost 1000 miles on my hawkeye and have taken it through dunes, mud, water, everything and never had that. i have sprayed down the shocks and all that with WD40. and i just thought about this, doesnt WD40 break down and like corrode rubber things like sealing rubber washers and stuff?
Old May 27, 2008 | 10:18 PM
Mongrol's Avatar
"Official Site Skeptic"
My experience has been the same as Hawkman. But its never seen mud or heavy dust. Becareful to get all the dust and dirt out before you lubricate anything. Itll just make a nice grinding paste.
Old May 27, 2008 | 10:28 PM
Hawkman300's Avatar
ya, i only lubricate the parts after a hard clean with the hose.
Old May 28, 2008 | 12:20 PM
sheepdogMSP8117's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: GunnSmoke
jokout is on the right path
i had/have the same problem. with mine it seems to be the inner bushings on the rear suspension.. each side has to bolts (upper and lower) that i take out, inside are those real good "self greased" bushings that don't work for crap... so about every 6 months i pull the bolts, bushings, pivot tubes and clean everything real good and pack in as much grease as it can take.. it gets rid of the creeking noise for a while...</end quote></div>
I had to do this on my '06, not a fun job but solved the problem.
Old May 29, 2008 | 08:09 PM
  #15
mjmmessina's Avatar
You guys where right, The top A arm bushings which are made of hard plastic where the culprit. When i loosened the bolts holding the top A arms, the creaking sound stopped. So I packed some synthetic grease around them and it seems to be ok now. Thanks for the help!
Old May 29, 2008 | 09:11 PM
  #16
TennesseeTider's Avatar
Was that on the rear? How hard was it to do? I swear mine creaks from the front.
Old May 29, 2008 | 09:52 PM
  #17
mjmmessina's Avatar
I hosed down the whole suspension, silicone sprayed all the bushings and after that I only noticed the creak in the rear. It wasn't bad. I just loosened up both bolts on the top rear suspension ( it stopped creaking as soon as I loosened up the bolts) and pumped some synthetic grease around the plastic bushings. I didn't remove them and pack them. If it comes back I'll do that. It doesn't look like there is tom much to removing them.
Old May 30, 2008 | 11:57 AM
  #18
GunnSmoke's Avatar
tennessee, it's not that hard of a job... i lift the rear end of the machine up with a floor jack and a section of 4x4 post, pull the rear wheels and then there are only 4 bolts (2 per side)... i can't remember the exact size of the bolts (13mm??) just pull those out and you might have to twist the bushings a little to get them out.. there will be 2 bushings and 1 pivot tube per bolt... CLEAN EVERYTHING REAL GOOD... even the inside of the pivot point... i try to put as much grease in as possible however it will be hard to get the bushings to seat properly with the grease not allowing the trapped air to be expelled properly.. then tighten the bolts back down (this usually seats the bushings) as you tighten you will hear the grease like you would if you were using your gun.. i cant remember off the top of my head what the torque specs are but if you need them let me know and i can post them for you when i get home and look in my manual
ltrmc02
Aug 22, 2021 02:34 PM
akguy31
Aug 31, 2019 04:34 AM
clscott84
Sep 21, 2015 10:16 AM
snowolson
Aug 31, 2015 03:51 PM
Sportsman850
Jul 31, 2015 04:25 PM
