Warrior Q
Old May 27, 2008 | 03:36 AM
MonsterWarrior's Avatar
Default Warrior Q
Hey i like to take advantage of the warriors power for trail riding and i wanted to know if any1 knows of a winch kit (other than Warn, too expensive) for cheap. Appreciate any help
Old May 28, 2008 | 09:57 PM
TomM's Avatar
Default Warrior Q
A winch wont affect the Warriors power at all. I put one from harbor Freight tools on my Bayou. It was $39 for the winch and had everything you defintely need but the mounting plates. I added a roller a heavy duty 12v breaker and some relays so I could use a toggle switch instead of the big bulky controller it came with I had around $150 in it all said and done. If you wanted super cheap you could make your own mounting plates and use the controller it comes with and be around 50-60. If you were mudding and used the winch a lot I would get a higher quality unit but for just in case it worked real good.
Old May 28, 2008 | 10:50 PM
WaRRiOr2069's Avatar
Default Warrior Q
if you want to add more horse power decrease the size of the rear sprocket and increase the size of the front sprocket.
Old May 29, 2008 | 12:15 AM
Default Warrior Q
Thanx bro i took a look at some there and im considering. One more thing tho, do u see much difference than stock with ur Raptor rear shocks?
Old May 29, 2008 | 12:17 AM
tricksh@t's Avatar
Default Warrior Q
or you could do the opposite because increasing the front and decreasing the back is going to gear you down which in turn gives you more torque and power but most likely all you have to do is change you front
Old May 29, 2008 | 12:20 AM
tricksh@t's Avatar
Default Warrior Q
sorry i wrote that wrong you should decrease the front and increase the back
Old May 30, 2008 | 12:30 AM
Default Warrior Q
i already have the 16 tooth front instead of the stock 13 nd it seems to be working well for me. My dad has a warrior with a 14 tooth and it rushes through first which i dont like the feel. Thnx tho
Old May 30, 2008 | 12:58 AM
TomM's Avatar
Default Warrior Q
The stock shock was blown when I got the quad so Im not sure. The Raptor shock was cheaper than a Warrior shock. The Z400 shocks on the front required brackets but made it ride like a whole different quad.
Old May 31, 2008 | 01:01 AM
Default Warrior Q
Oh thats cool. yeah once i start hitting jumps and riding harder i was thinking if the suspension's not great then i want to replace it with YFZ rear and maybe front but im not completely sure if the front fits
Old May 31, 2008 | 11:09 PM
Octane2079's Avatar
Default Warrior Q
THe yfz rear definitely won't fit and unless you cut and redrill the upper brackets the front shocks are going to be compressed and cause greater wear on your balljoints.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
