660R Clutch Problem ??
Old May 27, 2008 | 08:54 PM
anuf's Avatar
Default 660R Clutch Problem ??
Last weekend while riding, I noticed the power to the wheels abruptly decrease for about 1 second, then abruptly go back to normal. This week its happening much more frequent and getting worse. Clutch adjustment is correct, oil type is correct and oil level is correct. Is this a normal sign of a worn clutch? I would have expected it to slip and continue to slip (not re-engage abruptly)
Any suggestions?
Old May 27, 2008 | 10:31 PM
Raptor Man Dan's Avatar
I had a similar problem with my 04 after I did several engine mods, I replaced stock assembly with Hinson parts and a Barnett clutch and haven't had a problem since. On the otherhand if yours is an 01 you may have a failing transmission. My friend had an 01 and he stripped a few teeth and his would have abrupt split second power loss in 2nd and 3rd gears as it would come to the missing teeth. We thought it was a slipping clutch till we replaced it and it still had the same problem. We he took it apart and figured out it was missing gears he replaced his tranny gears with the Alba gears. He kept it for several more years without anymore problems.
Old May 27, 2008 | 11:19 PM
91Warrior357's Avatar
yea sounds like you just need new clutches,OEM clutches are awesome though sometimes better than aftermarket, raptor man dan is right about the 01 rappys i heard there trannys dont last 2 long, but just pull ur clutches out and see wut they look like, seems like there worn down and cant stay engaged
Old May 28, 2008 | 06:51 AM
anuf's Avatar
Thanks for the reply. The tranny was already upgraded in '03. It's gotta be the clutch. Looks like a fairly big job....pulling the engine and all.
Thanks again
Old May 28, 2008 | 09:12 PM
DollarBillz's Avatar
replace the clutch
Old May 30, 2008 | 09:35 PM
anuf's Avatar
WOW, everyone was wrong. Clutch is fine. In spite of already having my 2001 tranny upgraded by the dealer, second gear is gone! All the other gears are OK.
Oh well....
Old May 31, 2008 | 02:08 AM
ahh u never specified what gear it happened in lol o well good luck
skinnyr6
Aug 25, 2023 02:18 AM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
