no power on 05 400ex
Old May 28, 2008 | 10:45 AM
Coreysnow08's Avatar
Default no power on 05 400ex
My battery is good and when i turn the key i have no lights or no power to the starter. You can push start it and everything works when it is started. we tried jumping it from the solenoid it turned over but it was like the kill switch was off but it wasn't. I don't know what is wrong with??????????
Old May 28, 2008 | 11:03 AM
go-hard-or-go-home's Avatar
sounds like a loose conection. trry messing with your on/off switch. somtimes dirt gets in there and screws with stuff
Old May 28, 2008 | 11:11 AM
I have wiggled and cleaned everything and nothing works. Do you think it could be a bad ignition?
Old May 28, 2008 | 11:30 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Check that the fuse is not blown. The lights and starter are on the fused circuit.
Old May 28, 2008 | 11:35 AM
we checked the fuses they were bad but then we put a jumper wire in there to make sure it was the fuses and it still didnt work
Old May 28, 2008 | 01:46 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
<div class="FTQUOTE"><begin quote>Originally posted by: Coreysnow08
we checked the fuses they were bad but then we put a jumper wire in there to make sure it was the fuses and it still didnt work</end quote></div>
That's not a good idea. Fuses are there to protect components from a power surge. When mine did this it was the fuse on the left side next to the battery. There are two slots. 1 plugged in and one for a spare. I recommend keeping a spare. I went thru tones of them.
Old May 28, 2008 | 01:49 PM
Red Rider
The EX is famous for fraying/shorting wires up around the front lighting system. Check all these wires for a short that may be blowing you fuse.
If you replaced the fuse and it still didn't work, maybe you fried something when you jumped it????
Old May 28, 2008 | 02:03 PM
Koopa's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: reconranger
The EX is famous for fraying/shorting wires up around the front lighting system...</end quote></div>
I can verify that. That's exactly where my prob was. At one point I was fine as long as I didn't hit the bright lights. Once I did, BAM! popped the fuse and soon as I killed her I was changing it in the dark.
Old May 28, 2008 | 05:14 PM
kazuya's Avatar
always check the spark plugs first. never hurts to clean or replace them after every season.
then try the crabs and such.
if there is a fuel filter... start there.. otherwise you are in for pulling the carb and cleaning it...once you know the carb is clean.... add a fuel filter....then see how it runs. dont forget to count the turns it takes to screw in the adjustments... good luck.
________________
autopartswarehouse blog
Old May 28, 2008 | 05:40 PM
eprovenzano's Avatar
Check to see if the nuetral control switch (next to the shifter) is connected. On our 400ex, the same this happened, and the switch got disconnected. Reconnected, the neutral light came on adg the quad would start with the button.
2quiker
Mar 22, 2022 08:36 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
toonces
Sep 5, 2015 01:14 PM
