JUST REMOVE LOCK COLLAR!
Old May 30, 2008 | 11:02 AM
MECHANIKE's Avatar
Default JUST REMOVE LOCK COLLAR!
I'M TRYING TO REMOVE THE LOCK COLLAR ON A 01 SCRAMBLER 500 4X4'S REAR AXLE JUST TO TIGHTEN THE NUT ALITTLE, INSTRUCTIONS IN THE POLARIS SERVICE MANUAL JUST SAYS--REMOVE LOCK COLLAR--REMOVED CLIP,TRIED A BIG PAIR OF CHANNEL LOCKS TO BREAK IT LOOSE, NOWHERE TO PUT A PRY BAR,LOOKS LIKE THE ONLY THING HOLDING IT TIGHT IS THE FOAM SEAL+FORCE OF HABIT!!!! I'M SURE SOMEONE HAS THE TOUCH HERE,,,,,,,,,,,,,,,
Old May 30, 2008 | 11:06 AM
awsume800efi's Avatar
most lock collars need a hammer and punch, most are secured with a set screw i don't know about this one, then there should be another hole to put a ltittle punch in not sure if you have to hit it clockwise or counter-clockwise if i remember it is oppisite the rotation, hope this helps.
Old May 30, 2008 | 12:08 PM
MECHANIKE's Avatar
THANKS FOR YOUR INPUT,I'LL TAKE ANOTHER LOOK,I DID'NT SEE ANY FASTENING DEVICE OF ANY KIND....BESIDES THE C-CLIP......
Old May 30, 2008 | 12:42 PM
94harley's Avatar
Remove the c clip, remove the cover by sliding it off the nuts(pry it off inline with the axle), then you will have access to the axle nuts. It's actually a cover for the nuts, it won't turn. It needs slid off.
Old May 30, 2008 | 03:18 PM
MECHANIKE's Avatar
10/4 94 I WAS ONLY USING THE CHANNEL LOCKS TO WIGGLE IT OFF ALONG THE AXLE,I DON'T SEE A WAY TO GET BEHIND THE SLEEVE CAUSE THE HUB IS DEEP+THE END OF THE SLEEVE IS DEEP WITHIN,IS THE SLEEVE ON THE BRAKE ROTOR SIDE DOABLE,CAUSE THE PRY END IS RIGHT THERE,I DID'NT THINK THAT SIDE WAS ADJUSTABLE,IT SEEMS THAT SIDE HAS A STOP.
Old May 30, 2008 | 07:02 PM
MECHANIKE's Avatar
YEAH, IT LOOKS LIKE I'LL JUST PRY THE HELL OUT OF IT,10/4 HERE I GO............
Old May 30, 2008 | 07:18 PM
SCRAMBLER500XXX's Avatar
i have had to heat that sleeve up just to get it loose.
Old May 31, 2008 | 12:46 AM
MECHANIKE's Avatar
NOW THATS THE TICKET, I'LL TRY THAT FOR SURE IN A WEEK,THANX 500XXX
Old May 31, 2008 | 07:31 AM
drlang's Avatar
The lock collar will come, but the axle nuts don't like to move at all. Doc
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
