400ex smokes at start
smells like smoke, but it only does is for about 20 seconds after i first start it, kind of weird, i figured it would do it the whole time it was running if the motor needed to be rebuilt
it could be the valves, but if it is when you take the head off then also look at the piston and piston rings if you can see a dark spot on the piston( oil going through) then you will want a new piston to.
Bm400ex
Jun 22, 2015 09:16 AM
