400ex smokes at start
Old May 30, 2008 | 12:46 PM
arfountain's Avatar
Default 400ex smokes at start
My 99 Honda 400ex smokes at when I start it for about a minute or two. Do I need to rebuild the whole motor or can I just rebuild one part. Any advice would be great. Thanks
Old May 30, 2008 | 03:19 PM
trxguy9780's Avatar
is it gettin to much gas or is the smoke oil?
i have the same quad and it smokes oil and i have to rebuild the engine( the piston, piston rings, bearings, and gasket kit.)
Old May 30, 2008 | 03:58 PM
arfountain's Avatar
smells like smoke, but it only does is for about 20 seconds after i first start it, kind of weird, i figured it would do it the whole time it was running if the motor needed to be rebuilt
Old May 30, 2008 | 03:59 PM
arfountain's Avatar
sorry, it smells like oil burning
Old May 31, 2008 | 02:28 AM
KI6HNB's Avatar
Probably valve guides and seals. Time to send the head in for a rebuild. While it's in the shop have it ported too for some more power.
Old May 31, 2008 | 02:47 PM
trxguy9780's Avatar
it could be the valves, but if it is when you take the head off then also look at the piston and piston rings if you can see a dark spot on the piston( oil going through) then you will want a new piston to.
Old May 31, 2008 | 06:48 PM
Dans 07400ex's Avatar
valve seals
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
Bm400ex
Jun 22, 2015 09:16 AM
Jbird4681
Jun 9, 2015 01:59 AM
Hondaislife
Sport Quads
May 27, 2015 05:38 PM
1000gade
May 27, 2015 12:37 PM
