no spark
Old Jun 2, 2008 | 12:26 PM
go-hard-or-go-home's Avatar
Default no spark
got a new coil. it doesnt spark at all. what could be the problem with it. or is there some kind of wire or sourse that will make it fire. it seems some times and other times it doesnt. i checked all my wires. they seem to be all good.
anyone knows what controls the coil?
Old Jun 2, 2008 | 02:08 PM
jrafter's Avatar
Default no spark
could be the cdi......why did you replace the coil
Old Jun 2, 2008 | 04:29 PM
Default no spark
replaced the coil because of all the engine up grades. so i bought a new AMR CDI , and a AMR monster coil.
Old Jun 2, 2008 | 07:56 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Default no spark
Try it with your stock components and see if it starts. If it doesn't, you know what is causing the problem.
Old Jun 2, 2008 | 08:01 PM
jrafter's Avatar
Default no spark
the coil should be good the amr box might be the problem...........i have there coil and it works real good
Old Jun 2, 2008 | 09:44 PM
scott78's Avatar
Default no spark
You could have a crack in the fly wheel or a bad stator. I had the same problem with a warrior kept loosing spark so i replaced everything cdi coil stator all wires and it ended up being a hairline crack in the fly wheel. Hope it helps.
Old Jun 2, 2008 | 11:11 PM
asdfgh1's Avatar
Default no spark
go through the wiring and your stator could of gone out its behind your flywheel
Old Jun 4, 2008 | 03:50 PM
Default no spark
found it...it was a crack in the spark plug boot. tried to start it at night and saw a spark arch off the boot!!! fixed now, and runs great.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
