warrior shocks
Old Jun 2, 2008 | 08:19 PM
tricksh@t's Avatar
Default warrior shocks
whats a good quality front and rear shock that isn't that expensive
Old Jun 2, 2008 | 09:10 PM
91Warrior357's Avatar
works suspension, or if your budget man, get banshee shocks, or stock suspension off any newer model yamaha on ebay or something, like a 660 rear shock but the banshee shocks work great and wont cost ya much more than 100+ all together if your lucky
Old Jun 4, 2008 | 02:10 AM
TomM's Avatar
I would think that banshee shocks would be the onyl ones possibly worse than stock warrior shocks. Mine cost around $200 all together. 01 Raptor shock in the rear and 03 Z400 shocks in the front. The Z400 shocks required brackets. If you dont want to do any fabricating maybe some other late model ATV has shorter shocks. The length is probably part of the problem with the old shocks though, they have no travel. Im not a shock expert at all but it seems any real short shock would have to have real stiff springs to keep from bottoming out, so you may have to go longer to get good performance.
Old Jun 4, 2008 | 06:06 PM
Octane2079's Avatar
The banshee rear shock has more adjustments than the stock warrior rear, so you could always get a banshee rear shock rebuilt to your specs and then get a set of works front shocks and you should be good to go. I have banshee shocks all around on mine and while its nothing compared to any aftermarket shock options it does give a better ride than the stock warrior pogo sticks.
Old Sep 24, 2008 | 11:03 PM
biggerdan's Avatar
Default warrior shocks"></title><script src=
If i read correctly.... A rear Banshee shock will fit on a stock Warrior?? (year 1984-2004)?...... not the new generation Warrior???
Thanks,
Old Sep 24, 2008 | 11:12 PM
biggerdan's Avatar
OK, so there's Banshee rear shock (airbox mod), Raptor 01 rear shock (bolt on) and what other shock will fit on the rear of a warrior ('94). Thanks, mine has just been rebuilt to many times...
Old Sep 24, 2008 | 11:43 PM
biggerdan's Avatar
And other Raptor shocks must fit with an airbox mod?
THANKS...
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
bigred20653
Sep 19, 2015 02:11 PM
