96 Scrambler
Old Jun 4, 2008 | 07:56 PM
chevyman142000's Avatar
Default 96 Scrambler
Hi there, asking this on behalf of my friend. I had borrowed his 96 scrambler over the winter (before I finally bought a wheeler) and had taken it out in the snow and such. The next time I went to use it, the throttle was frozen, but it still started. I let it warm up a while and after that the throttle was fine. Needless to say, it froze up the rest of the winter. I since had taken it back to his place. Well, he now wants to sell it and we were trying to start it with no luck. The throttle is not frozen anymore (but does feel weird) but it does not start. We took the plug out and found that it does get wet and there is spark. We are not sure where to start. Any ideas?
Old Jun 4, 2008 | 08:21 PM
ftwflh's Avatar
Time to replace the throttle cable !Check out MotionPro before paying dealer prices.
Old Jun 4, 2008 | 08:56 PM
Do you think that is what is causing it not to start? I realize that is needs to be replaced either way though.
Old Jun 4, 2008 | 09:29 PM
ftwflh's Avatar
THe cable feeling wierd is a bad cable.You need to do a compresion check on the the motor and if it is over 100psi clean the carb.Mainly the pilot jet
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
