in gear starting
Old Jun 4, 2008 | 09:45 PM
wowkoolaid's Avatar
Default in gear starting
does anyone know how to disable the start in gear safty switch on a 350 rancher
Old Jun 4, 2008 | 10:16 PM
Jerkyking's Avatar
Why? Are you nuts?
Old Jun 6, 2008 | 09:19 AM
FourTraxMaxx's Avatar
just apply the front brake lever while bike is in gear should start as this works on most hondas.
Old Jun 6, 2008 | 09:59 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The new Rancher 420 will start in gear as long as the front brake lever is pulled. Never tried that on the 350, but I don't think that feature is available.
There have been numerous posts over the years about disabling this. Search and see what you can scare up.
Old Jun 6, 2008 | 10:54 AM
it works on my 400 rancher and my brothers old 2003 350 rancher
Old Jun 6, 2008 | 02:01 PM
hondabuster's Avatar
Is it an ES or S? The s can be rigged up, but the ES cant.
If you ground the green wire with a red stripe on the starter solenoid located near the battery. This gives you a neutral light and if you are in gear, it fools the computer into thinking it is in neutral.. Plus, if you wire a toggle switch into this new circuit you will have start in gear (turn off the switch once its started to turn off the neutral light)
Old Jun 7, 2008 | 10:10 AM
cody_lyons78's Avatar
just pull the front brake i hd to find that out the hard way when i parked it in gear in a river bottom and it was begining to flood i thot i woud have to leave it and hope for the best
Old Jun 7, 2008 | 11:14 AM
wowkoolaid's Avatar
as most of yall know sometimes u have to restart ur bike really quick esp if it going underwater i tried all the break levers and will not start in gear there must be some kind of switch anyone know?
Old Jun 7, 2008 | 02:48 PM
What year is the quad? The older ones dont have a start in gear feature, and you need to wire in a switch to fake it into thinking its in nuetral.
Old Jun 7, 2008 | 03:08 PM
wowkoolaid's Avatar
its an 06 350 4x4
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
Dabears1983
Jun 16, 2015 12:17 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
1000gade
May 27, 2015 12:37 PM
