2008 rancher 420 4x2 transmission problems?
I bougth the quad in March 2008 and when I use 4th gear it seems its going to explode.
at first the local honda dealer said it was a factory transmission problem, since they had already repaired another quad with the same problem and sold in almost the same period of time. And that other quads in the country had appared with the same problem.
When they call honda, they said that they had made tests to the transmission and determined that it was a missuse that caused the problem and no warranty was going to be given to any other quads.
But is it not wierd that more than two quads have had the same problem, bieng sold three months ago?
Lety me know if anyone has some information about this.
have you talked with the honda rep in your area.........call your dealer and ask them for his number.
if they ask why explain yourself and i bet they will help you out.
oh and this being your first post ..........lots of people come to the forums to complain.
hope this helps
hope this helps
I have a 2009 Honda rancher 420 with shifting problems, shifts from 1-5th then to neutral with a - code and it won’t start, turn it off and on you can here the transmission clicking, then it starts and may do it agin in a few minutes?. What a pain. Any ideas??
Firstly, 420 Auto or 420ES? Are you saying it changes up and down OK except when you change into neutral? If you don't do this "on the move" the gears will not mesh properly and you get that - on the display, until they have meshed, which requires the bike to be moving.
bzdok1234
30
Feb 23, 2016 01:55 PM
