my 4x4 is a 4x3... spliced wire goin to hub..
Old Jun 8, 2008 | 09:40 PM
HARLEY_OWNER's Avatar
Default my 4x4 is a 4x3... spliced wire goin to hub..
so only 3 wheels spin.. today i looked at the wire running to the hub and noticed it was spliced like maybe it was broke and someone fixed it.. well the electric tape was comming off and was all wet... could this be the problem?>
Old Jun 8, 2008 | 09:43 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you need to make sure it has good connection for sure as it could be the problem. just a guess.
Old Jun 9, 2008 | 12:12 PM
could because it had gotten wet.. made it not work?
Old Jun 9, 2008 | 12:57 PM
mrprpane's Avatar
when you put it back together use some heat shrink tubing on it
Old Jun 9, 2008 | 08:23 PM
ok so i took the crimp off and just twisted the wires together real good,,, i didnt go mudding to test it i wrapped a belt around a tree and around the hitch and tryed the 2 wheel first to make sure the tree would hold.. then 4x4 and still only three wheels spun.. im thinkin maybe the fluid now.. but it looks as though maybe the allen screw is partially stripped is there anything i can use to get that screw out?
Old Jun 9, 2008 | 08:32 PM
also it dies when i put it in reverse... but i can hold the override and use my foot to put it in reverse and it works.. dont kno if that maybe have somthing to do with it or not
Old Jun 9, 2008 | 08:35 PM
sled05's Avatar
Buy a set of easy outs. They thread in counterclockwise
Old Jun 10, 2008 | 03:10 AM
user493's Avatar
Moto Psycho
<div class="FTQUOTE"><begin quote>Originally posted by: sled05
Buy a set of easy outs. They thread in counterclockwise</end quote></div>
If you don't want to buy a whole set, you can also get a single screw extractor (easy out) that comes with the correct size LEFT-HANDED drill bit. If you have to drill the hole deeper and the bit catches, it will help unscrew it, instead of making it worse like a right-hand drill bit would.
From Wikipedia:
... They may also be used as an aid in the removal of common right-hand screws. Since the rotation of the drill bit is such as it would loosen the screw, using it to drill into the damaged screw head will usually remove the screw, providing the bit "grabs" the damaged material successfully.
COFatboy
May 2, 2020 12:06 AM
toonces
Sep 5, 2015 01:14 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
quickwhips
Sep 2, 2015 06:53 AM
DeFox500
Jul 26, 2015 06:32 PM
