93 300ex engine problems
I rencently heard a ticking coming from the head of the motor and when i took the top of the motor off i found the two bolts holding the timing sprocket onto the cam shaft had stripped out and the sprocket itself had cracked and warped. I bought a knew sprocket camshaft and bolts and put everything back together but it wont start. It will turn over but wont start even with starting fluid being sprayed into the air assembly. Is there anything i need to know about how the sprocket liines up with the stroke of the valves or anything thanks
The cam/sprocket must be timed .. If it was turned over before it was timed the valve/s are probably bent now...
