Bayou 220 problems (please help)
Old Jun 11, 2008 | 03:17 PM
tsanko's Avatar
Default Bayou 220 problems (please help)
My Bayou 220 electric start won't work, when it just worked 2 days ago. I think mayb the starter motor may be bad, but how do i tell? and mayb the relay assembly? give me some tips to try please, to either find out if they are bad, or if there is a common fix. thank you!!!
Old Jun 13, 2008 | 04:50 PM
Hayashi's Avatar
I already posted the answer to this issue before but here it goes again.
It is ground wire that runs from the starter solenoid to the left side frame. The wire connection to the "painted" frame is the problem causing intermittent connection. Sand/file down the paint and reconnect the connector to the bare metal frame and cover it up with di-electric grease to prevent rusting. Do a search to find my previous post for more detail.
Old Jun 17, 2008 | 01:33 AM
hotrod60's Avatar
atv repair center told me they put a hot wire from the battery to the nut on the starter to see if stater turns over. Mine did not they wanted $300.00 for a new starter and labor. found one for $84.00 on ebay and did myself took about 1 1/2hours. you have to remeve exhaust pipe and slide it out of the way and remove oil line to the top of cylinder head and the cross over line to the left side of engine. be carefull not to over tighten oil lines when replacing them . take note of copper washers on the oil lines, this makes the seal when engine is running. good luck
Old Jun 17, 2008 | 11:43 AM
Hayashi's Avatar
Starter on Bayou 220 or 250 rarely goes bad, very rare. Usually it is a connection problem, cheap fix. Don't get ripped off.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
rcappie4
Jul 18, 2015 07:51 AM
Sjrpp
Jul 5, 2015 09:04 PM
