Whats wrong with my ride??
Old Jun 15, 2008 | 05:03 PM
LY800sp's Avatar
Default Whats wrong with my ride??
My 97 magnum 425 2x4 will not go or stay in rev.while running. When i shift it to rev. it makes a knocking noise inside the belt cover box? If i hit the gas it starts knockin faster but dosen't move. I turned the bike off and put n rev. then cranked it and it work o.k. for a minute but then started knocking again. It almost seems like its not in gear the whole way? Anybody have any idea whats up?
Old Jun 15, 2008 | 09:41 PM
mkgearhead's Avatar
My '96 had the same problem. There was too much play in the shifter assembly and it wasn't going all the way into reverse. There was also some play in the transmission case where the shift lever goes down into the transmission. I lucked out and it was fixed with just the shifter. Anyway I'd check all the linkages for play and go from there.
Old Jun 15, 2008 | 09:53 PM
user493's Avatar
Moto Psycho
Yep. Adjust the linkage.
Old Jun 15, 2008 | 10:26 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
worn linkage and out of adjustment.
Old Jun 15, 2008 | 11:57 PM
LY800sp's Avatar
Thanks fellas i just got thru lookn an found those adjustments on the shifter. Sems like its fixed. I'll c if it stays that way. Thanks again
neilbedwell
Nov 10, 2018 11:02 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Mphillips
Jul 29, 2015 08:53 PM
sut3000
Jun 26, 2015 05:54 AM
