engine clanking when starting
Old Jun 15, 2008 | 11:52 PM
95warrior350's Avatar
Default engine clanking when starting
i just got a 95 warrior 350 from my cousin and when i start it it has bad clanking like noises coming from the engine and i have checked the bearings on the starter gears and there fine i am open to any ideas on what this is.
Old Jul 8, 2008 | 01:20 PM
54warrior's Avatar
It's the starter clutch assembly which is located behind the flywheel on the left side. You'll need a flywheel puller to access it.
Old Jul 16, 2008 | 11:36 PM
firemanjim's Avatar
what do theses bearings look like?Is it commons for the bearings on the starter gears to come apart?Abuddy of mine found some small needle looking bearings in his oil on his 97 warrior
Old Jul 17, 2008 | 12:02 AM
warhorse20000's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: firemanjim
what do theses bearings look like?Is it commons for the bearings on the starter gears to come apart?Abuddy of mine found some small needle looking bearings in his oil on his 97 warrior</end quote></div>
I wouldent think this guys Starter or cluch Problem would be the needle Bearings your asking.
My guss would be Needle Bearings From The Conecting Rod , or Under the Wrist Pin , on the bottom of the Piston.
But i could be wrong..
Old Jul 17, 2008 | 12:57 AM
firemanjim's Avatar
so the connecting rods and the wrist pin have needle bearings?
Old Jul 17, 2008 | 11:27 AM
i believe most small engines dose have needle bearings , on the wrist pin as well as conecting rod[s] .
you can check that fairly easy you know w/out takeing anything majour apart.
just remove the sparkplug , place a screwdriver on top of piston and hold it and manuly turn over engine slowly, If you Feel Like something is To Loose , or get get a Bumpy Kinda Feeling , or real Sloppy: you know that 1 of them Bearings is shot , Now That test will only Do the Conecting rod & Wristpin Bearing. But at least you will know.
As normal bearings should be smooth and firm feeling on the piston , and thier should not be much wiggle on the piston.
Old Jul 18, 2008 | 12:10 AM
91Warrior357's Avatar
yea its the one-way starter clutch, there noisey anyway but when they start to wear down they get even worse
MikeyBoyesq
Nov 27, 2020 02:44 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
alix
Jun 28, 2015 03:28 AM
kevbowe
Jun 1, 2015 01:17 AM
1000gade
May 27, 2015 12:37 PM
