can i please get some input!!!
Old Jun 17, 2008 | 10:28 AM
04500icat's Avatar
Default can i please get some input!!!
04 500i auto..............26 inch mudlites tranny snorkel.disconnected actuator from front ent becouse it was stuck between 2 and 4 wd.i hit the gas sounds like bearings rollin just inside the box.it gets hot pretty fast as well.i was going to remove the cover today but i need to know what to do and look for.is this a cheap fix?someone said something about the 4x4 solenoid.where do i look for that?maybe i needed to clean it?i could use all the help i can get.thanx
Old Jun 17, 2008 | 11:51 AM
tancat500's Avatar
whats getting hot?
Old Jun 17, 2008 | 01:22 PM
swampyjunior's Avatar
Yeah, which part is getting hot?
If it s the black actuator box, then I do not believe it is sevicable only replaceable. If it is the front differential then you might check what its fluid level is and/or drain its fluid and see what kind of metal shavings you get out of it.
If you need help identifying the parts try finding an online microfiche parts diagram for your machine. Try brownsleisureworld.com it should be there.
SJ
Old Jun 17, 2008 | 04:21 PM
04500icat's Avatar
the tranny box,the engine.like i said i hit the gas and it sounds like bearings spinning just inside the tranny box.
Old Jun 21, 2008 | 07:57 PM
Bobmack's Avatar
maybe this is what you need http://cgi.ebay.com/ebaymotors...QrdZ1QQsspagenameZWDVW
Joe454
Nov 20, 2020 01:19 PM
shimanok2
Jan 29, 2016 07:37 PM
Hack714
Sep 26, 2015 08:11 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Hack714
Sep 20, 2015 05:54 PM
