'00 Wolv. cutting out!
Old Jan 30, 2000 | 01:27 PM
MDP49's Avatar
My '00 Wolverine is cutting out and sputtering when I go up a hill or cut donuts. I recently got water in it, but I thought I got it all out. I cleaned the carb and added some gas treatment but it still does it. Any ideas?
Old Jan 30, 2000 | 08:54 PM
sparkys's Avatar
I would try by checking your float height
first. This is a very important thing that a lot
of people overlook. If the height is too low
the bike will starve when accelerating hard
up hill etc.
Old Jan 31, 2000 | 05:14 PM
PamFalcioni's Avatar
Where did the water go? Into the engine? was it running at the time?
It may be something as simple as a bad ground on the reverse selector. Could be as bad as worn piston, rings and valve guides from a hydraulic seizure.
pam
Old Jan 31, 2000 | 06:36 PM
wolv99's Avatar
I would agree. check the floats.
99 Wolverine, FMF MegaMax2 Pipe, K&N jet kit, Pro Flow Intake system w/Outwears, OxLite brush guards, Front/rear Skidplate, DuraBlue Elimanator axle, lift kit and 25" Kenda BearClaws
Old Feb 1, 2000 | 08:54 AM
MDP49's Avatar
This Wolverine is only 3 months old...should I already have to adjust the float position? Would getting water in the carb change the float position? I'll check it. Thanks.
Old Feb 1, 2000 | 09:06 AM
MDP49's Avatar
If I had done damage to the pistons, rings or valve guides, would there be any signs? Would it smoke or make a particular noise? It only cuts out now when you go up a steep hill or cut alot of donuts real fast. It acts like it's either not getting enough gas or not getting fire. I didn't think it was a gas problem, because every now and then when it's cutting out, I can smell gas. But most people that I've heard from say check the float...so I will.
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Bernhard
Sep 25, 2015 12:45 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Elkaholic
Sep 6, 2015 02:44 PM
