Raptor 80 will start then stop running....
Old Jun 21, 2008 | 10:34 AM
hrtool's Avatar
Default Raptor 80 will start then stop running....
i am trying to fix my raptor 80 and i have top push start it then it will start to run but then shortly die out.. iu have cleaned out the carb and she is getting spark. then when it dies out if i push it again it will do the same thing. just cant get it to continue to run...need help.....
Old Jun 21, 2008 | 10:17 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
You said you cleaned the carb.
Did you pull the pilot and the main jet's out of the carb and make sure they are cleaned out?
Did you blow carb cleaner thrue the pilot jet passage way?
Did you open the drain screw at the bottom of the carb while the gas tank pitcock valve is open to verify that you have a good gas flow into the carb and the gas tank vent is not clogged.
Also did you put in a new spark plug
Just a few basics you didn't give allot of information if you didn't do these thing try them and try to give a better description of what it is doing like flooding out or running lean.
Old Jun 21, 2008 | 10:21 PM
Tpsycho's Avatar
Also make sure your air fillter is cleaned really well.
I have had plugs that get spark but have a bad slight short so once the motor starts running the plug can not perform properly and the bike dies out shortly after starting.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
1000gade
May 27, 2015 12:37 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
