blowin smoke
Old May 28, 2008 | 11:06 AM
digginitwit's Avatar
Default blowin smoke
can anyone help me figure out why my yamaha wolverene 350 is blowing black smoke. It idles great but when I throtle it up, it runs rough and blowes black smoke. I cleaned the carb. changed the air filter.
Old May 28, 2008 | 11:15 AM
Coreysnow08's Avatar
Is your exhaust tip have an oily coating on it? it could be shooting oil because mine has done that before.
Old May 28, 2008 | 11:26 AM
not yet. but I'm sure it will if I can't fix it. what was the problem with yours.
Old May 28, 2008 | 11:33 AM
I needed to jet it
Old May 28, 2008 | 01:03 PM
what do you mean " you needed to "jet" it"
Old May 28, 2008 | 08:09 PM
2Owanage's Avatar
The jets in the carb are not correct
Old May 29, 2008 | 02:48 AM
Thanks for answering. do you think this would cause fuel to spit back into the air box. Thats what mine is doing. It seems like its getting more gas than it can burn. I've adjusted the slide piston and it helped some. could my timing be off.
Old Jun 19, 2008 | 01:23 PM
Laeagle350's Avatar
I had a similar problem. If you have an aftermarket air filter your jetting may be different. Try a smaller jet. Running too rich (more gas then needed for the amount of air) will cause you to burn more gas and therefore black smoke. Other than that make sure your intake is clean as well as your airfilter.
Old Jun 21, 2008 | 02:04 AM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
if you have a diaphram type carb you could have a hole in the diaphram so you are getting gas but your slide is not lifting and it is flooding your motor I have seen this when people put large K&N filters and take the lid off of the air box without putting in a lighter slide spring it won't have enough vaceum to lift the slide.
Remember Black smoke equals to much gas and white smoke equals burning oil.
Hope this helps you out.
Old Jun 22, 2008 | 09:33 AM
cadillacdude1975's Avatar
take it to the dealer and have the carb adjusted. that is the most simple solution.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
