Sprocket change...
Old Jan 25, 2001 | 09:21 AM
325boss's Avatar
hey guys,
as wondering if i might go up one tooth on my front sprocket, have heard from some that that will give my boss a top speed like the Blazer, but will it accelerate painfully slow? if it does, screw that, i like it how it is, but if i can get more with that change, may be worth it.
Old Jan 26, 2001 | 12:41 AM
NewDSLover's Avatar
You shouldn't notice that much of a take off change because of your auto-trans.
Old Jan 26, 2001 | 07:21 AM
SMBLACKNIGHT's Avatar
the trail boss is too tall geared now let alone going up a tooth on the front sprocket. If you do this you will loose speed and be a lot doggier on the take off. The boss has an 11 tooth on front and a 42 on rear, you need to go a little bigger on rear sprocket which will help take off as well as let the engine rev a little higher.
Unless you have gotten an extra 10 horse or so do not gear it any higher unless one of your friends has a 500 and has a rope tied on your front.
realoldguy
Old Jan 26, 2001 | 11:29 AM
Farmr123's Avatar
I had a 400 Xpress that had taller gearing installed. Putting in a green primary spring (white may be better for a 4 cycle) gave it the same acceleration it always had, and gained in top speed. Keep in mine you lose some low-speed control when you do this as the enging revs higher before the clutch engages, making engagement more abrupt.
However, I don't know how it would work in a 325. The 400 has enough power to pull the higher gearing, I don't know if the 325 would or not.
Old Jan 26, 2001 | 05:49 PM
325boss's Avatar
SMBLACK,
If i do that, will it be slower on top speed?
Old Jan 26, 2001 | 06:48 PM
Jack's Avatar
You really need to do something to the 325 to get it to go faster first, before you change gearing. Gearing will not help a stock atv go faster, it might even hurt. Check with RcR, he's got some speed part for those 325's that really perk them up.
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
