Warrior toasted another CDI
Old Jul 4, 2008 | 11:19 PM
ftwflh's Avatar
Default Warrior toasted another CDI
What would cause a CDI to go bad after just 3 weeks.Ran good until yesterday and when he shut it off it wouldnt fire.Check plug it wasnt firing and the CDI smelled burnt.AnyIdeas
Old Jul 5, 2008 | 12:43 AM
91Warrior357's Avatar
id have to think somethings funky in the wiring harness and shorted it out or something
Old Jul 5, 2008 | 09:29 AM
ftwflh's Avatar
I am thinking maybe a surge from the voltage regulator but it could have been a faulty unit.I am going to call ProCom monday afternoon.
ANYONE ELSE HAVE ANY IDEAS like where a bad wire could be?I took the zip tie off the wires on the rear of the frame.
Old Jul 5, 2008 | 01:16 PM
Check stator specs (dealer or clymer manual) stator could be source if out of specs, could be frying cdi?
Old Jul 5, 2008 | 02:52 PM
ftwflh's Avatar
Thasnks.But wouldnt the regulator get toasted first?
At least that is how it happens on my Harley but who knows on this jap stuff.
Brad
Old Jul 5, 2008 | 07:43 PM
Not always! Stator has pulse coil that sends current to cdi,also charging system (usually yellow wires that send ac current to reg/rectifier which changes ac to dc and sends to battery between 13.5-14.5 dc volts. If reistance checks on pulser ok and resistance on charging wires good and no shorts to ground this can possibly eliminate stator as source of problem. Elec diagnoising sometimes hard not being able to have HANDS on to check out! Also check kill switch housing for shorting to ground.If can disconnect ,Not sure on Yamaha,but polaris cdi has black wire to kill switch.
Old Jul 5, 2008 | 11:16 PM
ftwflh's Avatar
I wish this was a POLARIS
Thanks I will get the tester out and check the stator.
I have never had this much trouble on any other quad.
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
WilliamBos
Sep 22, 2015 04:07 PM
01ssls1
Sep 22, 2015 06:50 AM
Steeldon
Sep 9, 2015 09:38 AM
