95 Warrior
Old Jul 7, 2008 | 11:16 AM
clbuck29's Avatar
Default 95 Warrior
I have a 95 Warrior and it act like it is flooded or not getting enough fuel. It is an intermittent issue. Any ideas?
Old Jul 7, 2008 | 05:00 PM
embler's Avatar
Default 95 Warrior
check the carb boot, one going from the carb to motor. check for any rips or holes in it. also check all the vent lines coming from the carb and make sure they are there and not kinked up or clogged. lastly, the float in the carb may be sticking or there may be trash blocking a jet. clean the carb real good and blow out the jets with air. hope this helps
Old Jul 7, 2008 | 10:28 PM
91Warrior357's Avatar
Default 95 Warrior
well you need to determine if it is flooding or if its startving itself of fuel, does it idle ok? when does it act up what rpm? prolly just a dirty carb, on the warriors most people dont do this but its always a good idea to run an inline fuel filter, keeps the carb cleaner for a longer period of time, but try to determine a little more detailed of what hapends cuz it could be a million of things
Old Jul 8, 2008 | 11:08 AM
clbuck29's Avatar
Default 95 Warrior
I tried to start it last night. I could get it to start by pushing the throttle all the way and then starting it, then it would run for about 30 seconds and die. Not sure anymore guess it is more starving for fuel
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
