96 Sportsman 500 Flywheel?
Old Jul 10, 2008 | 05:19 PM
Jester2899's Avatar
Default 96 Sportsman 500 Flywheel?
Anyone know of a 96 sportsman flywheel can be replaced with a newer year? If so up to what year? Thanks.
Old Jul 14, 2008 | 10:13 PM
Never tried but older models have exposed magnets in flywheel,while newer ones are inclosed! Like I said never tried only replaced a couple older model flywheels and stators when stators were destroyed by chipped/broken magnets! Maybe someone HAS! I just work with STOCK replacement,but good question though!
Old Jul 14, 2008 | 10:23 PM
Jester2899's Avatar
Thanks for the info. The only reason I am asking is because I am having an extremely hard time find a 1996 flywheel used. I don't want to spend 300$ on a flywheel for a quad that I got for free.
Old Jun 14, 2022 | 10:18 PM
outdoorsportsman's Avatar
Just wondering if you ever found newer replacements...i am going through that right now with discontinued parts
Old Aug 16, 2022 | 05:07 PM
Brandonradtke's Avatar
I am wondering as well
Old Aug 16, 2022 | 06:30 PM
Hey no I have not found a aftermarket supplier…I did find a used one and ended up with that. I did find eBay for a stator though around 60$ and it works.
Old Aug 18, 2022 | 06:55 PM
astrebin@gmail.com's Avatar
Default 96 sportsman stator/ignition swap
I recently bought a 96 sportsman 500 with a bad flywheel & the only replacement was on eBay for $400 & was an ff95 but I couldn’t tell if the other set of numbers was the same or not & I’ve heard people have a very hard time finding them. I already had an FF97 flywheel & stator & cdi & I had to order the correct stator plate & also had to change voltage regulator but it runs great & now I believe is a high output system
f250
Sep 30, 2024 08:07 AM
billywhitetail
May 19, 2013 03:14 PM
pdqw
Feb 13, 2008 08:37 PM
f250
Dec 5, 2007 10:07 PM
