Progressive springs owners!
Old Jan 25, 2001 | 10:33 PM
YellowFellow's Avatar
Has anyone ever turn them right up? I read that if ya turn them all the way up it could cause cv failure, does anyone know this to be true?
Old Jan 26, 2001 | 01:16 AM
Englishmatt's Avatar
Depends how you ride. the harder you have them then the harder the hit will transfer from the wheels but thats a fair enough risk isnt it.If you ride the rocks like mcnutt or Chilliwack you might do damage but in the mud I doubt it.
Later
Matt 2000 500 Scrambler.
Old Jan 26, 2001 | 03:24 AM
Thanks, but it's for the mud. I just installed 28 Outlaws with 9.5 in the front. The springs are halve way up and the floor boards are moved about a quarter of an inch back. The problem is that when hitting a bump the tire grabs the front of the fenders. Anyone have any other ideas, maybe moving the floor boards back to stock location?
Old Jan 29, 2001 | 03:55 PM
rangerchet's Avatar
Well as a 2000 polaris xpedition 425 cc 5-speed owner. I have a similiar experience. However, I bought 26 inch mudbugs. You have 28 inch outlaws. I had the same problem where bumps caused tire fender rubbing and I did not like it. I have the progressive lift springs. All that is, is heavy duty springs and those cams. They are up as high as they can go. I have no more tire fender rubbing and that makes me very happy. However like I said,
you have 28 inch tires. I believe that they cause no extra wear on tie-rod ends or cv joint problems. As you know, lift kits definitely do.
rangerchet
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
speedbuff
13
Nov 11, 2020 10:16 AM
Customer Service #1
May 15, 2020 08:46 AM
Ahtatu
Sep 28, 2015 12:14 PM
