Winch Cable
Old Jul 11, 2008 | 05:18 PM
Marksvilleman10's Avatar
Default Winch Cable
Can anyone tell me the best way to cut winch cable? I have a section of cable that got hung up in my winch and is frayed badly. I would like to cut this portion off but am worried about the good portion fraying after I cut it. Should I tape it?
Thanks
Old Jul 12, 2008 | 12:01 PM
BigBros_Farmtoys's Avatar
Default Winch Cable
I've always bound it before I cut it
Start an inch or so one side of where you plan to cut and then wrap tightly with Electrical tape.
You can go across the point you intend to cut then cut through tape and all.
Mostly it depends on how you plan to cut the cable.
Old Jul 12, 2008 | 01:43 PM
tipo176's Avatar
Default Winch Cable
Or you can buy a Amsteel blue rope. Then you dont have to deal with this problem any more. http://www.amsteelblue.com/
Old Jul 12, 2008 | 10:59 PM
700 sportsman's Avatar
Default Winch Cable
you could tape it and use a grinder, dremel tool, or maybe bolt cutters
Old Jul 13, 2008 | 02:43 PM
Rowe's Avatar
Default Winch Cable
Tape and bolt cutters should do the trick. I'd just with the rope do a search and you'll see the topic in pretty good detail. I'm waiting for mine to fray so I can replace it with the rope!
Old Jul 14, 2008 | 11:28 AM
Default Winch Cable
Thanks for the input on the winch cable. Seems easy enough to fix. I will cut off the bad part for now. I will have to invest in that amsteel blue rope when the rest of the cable gets rough.
Thanks.
Johnny Mac
Aug 15, 2019 03:13 PM
Whitelx1
Oct 2, 2015 10:55 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
chewy78
Sep 8, 2015 10:37 AM
