AWD
Old Jul 11, 2008 | 11:36 PM
ohiosportsman1's Avatar
Default AWD
I have a 2000 sportsman 4 x 4. this is the first polaris I have owned. I am not shure if the awd is operating correctly. The steering is very hard so I am thinking that it is in awd even when the switch is off. It seems to be in 2 wheel drive in reverse with the overide in. Is this correct?
Old Jul 12, 2008 | 12:21 AM
MaineWheeler's Avatar
Default AWD
Next time its hard to steer try wiggling the handle bars while backing about 5-10ft and see if that "cures" it. Sometimes they act like one of the older 4wd pickups and by going backwards you disengage the 4wd
Old Jul 12, 2008 | 12:23 AM
hddoperator's Avatar
Default AWD
You should have AWD in reverse if the overide is in.
Old Jul 12, 2008 | 07:33 AM
Default AWD
hd - do all years go awd in reverse when overide is pushed in? or do you know when the system started operating like that?--thanks
Old Jul 12, 2008 | 12:15 PM
TLC's Avatar
TLC
Default AWD
Since day one 1996 to present the Sportsman's needs the override button pushed to have AWD in reverse gear.
Old Jul 12, 2008 | 01:34 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default AWD
it would eay to tell just my throttling it fast to spin the wheels. if it spins the rear wheels its in 2x4. and it will not go into awd in reverse w/out pushing the override unless someone has done a bypass over the override button.
