200s recoil starter question...
Old Jul 12, 2008 | 04:16 AM
MonkOFox's Avatar
Default 200s recoil starter question...
ok, I put the pulley in there and everything, and is pulls back when I lay it on it's side, but as soon as I put the thing on the trike, the rope just pulls out and doesn't recoil, is it the spring that is bad? and why does it catch sometimes and not others?
It's really fustrating me,
Thanks,
Monk
Old Jul 13, 2008 | 03:20 PM
SMFREY's Avatar
It is probably either deaging or not enough spring tension
for some times not engaging possibly a little lube
Good luck
Ray
Old Jul 14, 2008 | 04:42 PM
MonkOFox's Avatar
I know what the deal is, I wasn't "pre-loading" the recoil spring and the pulley 2 360 degree turns, before wrapping the excess rope around the pulley and then through the pulley hole in the recoil starter case.
the tension from the pre-loading should fix my problem.
Thanks,
Monk
akguy31
Aug 31, 2019 04:34 AM
Coondoog
Technical and How-To Articles
Sep 9, 2015 01:51 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
