no 4wd in forward or reverse
Old Jul 14, 2008 | 11:51 AM
Taker's Avatar
Default no 4wd in forward or reverse
I was wondering if someone could point me in the right direction I have a 04 SP600 I have no 4wd in forward or reverse it lights up and says it working on the display and when the overide is pushed while in reverse it also says its working . I put it up on my motorcycle jack so all 4 wheels are off the ground and only the back wheels spin. Please correct me if iam wrong but should both front wheels be locked together if the cage is broken? I have turned both of mine while in the air and each one is free ,they turn seperatley. The battery is fully charged. I dont really have the $ to take this in to get fixed but I will if i have too Thanks in advance
Old Jul 14, 2008 | 12:59 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i think you hit the nail on the head w/ the cage being the issue imo.
Old Jul 14, 2008 | 01:16 PM
Taker's Avatar
i used a test light to see if I had current coming from the 2 wires the go into the front differential and I have current enough to light a test light with the 4wd switch on
Old Jul 14, 2008 | 04:25 PM
If 12 volts going to gearcase, can still be mechanical problem as posted above!
Old Jul 15, 2008 | 02:04 AM
Taker's Avatar
I drained the front diff and got just a very little water out of it. and no oil . I put the right polaris diff oil back in but still nothing, would it be possible that the magnets in there are dirty and it needs to be flushed real good it never quit working all at once for awhile i only had 4wd in forward, not in reverse, Then I had not ridden it for about 6 months and now I have no fwd in forward or reverse
Old Jul 15, 2008 | 08:22 AM
atv gooroo's Avatar
Water and no oil. That sounds like toast. I would bet that all the plastic parts in the awd are all one peice now. Some of these plastic parts are not replaceable. And as for the water, the rollers are pitted and rusty and are seized up in that pile of melted plastic. I think that you are lucky because most of time its the revese effect.(wheels stay locked in) I will be the first to tell you that even if you do the work yourself it is going to cost you a pretty penny. New front end is around 900 dollars. Parts to rebuild if you can get all of them is around 300 dollars. 2 days of work too.
Old Jul 15, 2008 | 08:27 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you had to oil inthe front end, you have got some bad problems. i hate to say it but the front end needs to come apart. if the roller cage is bad then do a search on here and find a john deere replacement.
Old Jul 15, 2008 | 01:19 PM
Taker's Avatar
Thanks for everyones help it looks like it might be a later project I will keep everyone posted is it hard to change the cage yourself with a manual
Old Aug 4, 2008 | 06:51 PM
Taker's Avatar
I just picked up a good complete front differnetial with axle shafts for a 04 SP700 from a friend of mine for $300 I am sure I got a good deal Iam gonna try to get it together in the next week. I will keep you all posted on how I make out.
Old Aug 16, 2008 | 12:22 AM
Taker's Avatar
I just the got the new front diff put in and everything seems to be working fine I took the time and tore apart my old front diff and the roller cage is good , everythig was coated with what seems to be dirt/sand and water its almost like mud, Iam gonna get into it more tomorrow but I'm hoping i can just give everything a real good cleaning then I will have a extra diff , thanks for everyones help
