4x4 locking
Old Jul 14, 2008 | 01:06 PM
200es's Avatar
Default 4x4 locking
in my 500 scrambler the 4x4 locks and pulls it hard from one side to the ofter, can i remove the clutchs in the hubs and use it as 2x4 untill i fix it?
Old Jul 14, 2008 | 04:23 PM
Default 4x4 locking
Sounds like armature plates sticking,low on fluid,bad bearings? If going into hubs,replace worn parts!
Old Jul 18, 2008 | 12:42 PM
200es's Avatar
Default 4x4 locking
when i took it apart i noticed the armature was stuck "still magnatised i removed it and put it back on and no longer sticking, also i noticed the bearing wernt tight the iner-race had alot of play to it, i use normal atf fluid, in the manual it says use atf type f fluid, is there much difference between the two?
Old Jul 18, 2008 | 01:04 PM
MECHANIKE's Avatar
Default 4x4 locking
the awd will not work if loose+damage can result.tighten properly.f fluid is ok.....
Old Jul 18, 2008 | 06:52 PM
MaineWheeler's Avatar
Default 4x4 locking
Went through what you are experiencing and tried the ATF, the only thing the ATF is good for is cheap flushing of system, went to Polaris demand drive fluid afterwards and have had no more problems. Its well worth the extra money, a quart lasts through a few hub changes and the hassle free operation alone justifies the cost.
Old Jul 19, 2008 | 01:12 AM
ncriderforks's Avatar
Default 4x4 locking
Sudden AWD engagement can be caused by a warped driveshaft or propshaft. If it takes some speed for it to engage then I would not rule this out. The hubs are not always the unwanted engagement problem ( not saying they can't be) If you don't know what you are doing with the hubs then TAKE IT TO YOUR DEALER!!!!!!!!!!!!!!!! If you arn't careful then it can cost you alot of money. I've been working on Polaris for 10 years. The AWD is the most simple design to work on there is. It can also be the most complicated if you don't know what you are doing.
greg74
Sep 10, 2019 03:03 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Findlay Tulloch
Aug 25, 2015 05:00 PM
