FIXED!!! 350 W Dies in rev, only starts in Nuetral
I flipped my quad down a hill about 7 times. After several replacements I am happy to say it fired right up and is running well except it will only start in Nuetral and as soon as you drop in in reverse in stalls.
Any advice??
Thanks
Any advice??
Thanks
Yeah, assuming it's a Warrior, it has a neutral sensor on the left side of the crankcase (when sitting on the bike), near the gear shifter almost at the bottom of the engine. Make sure that wire is on the prong that it needs to be on.
Ok...F I N A L L Y figured it out....there is a clutch safety switch attatched to the bottom of the clutch perch on the handlebars. the wires lead down under the headlamp assembly and a wire came loose.
By the way if your neutral sensor is unplugged, it will not start at all.
Thx for the help
Thx for the help
whitty
67
Feb 24, 2021 02:52 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
