Battery for Sportsman 800
My friend found out with his 660 Grizzly that the bigger bore ATVs with no decommpresion reguire a more exspensive battery , a cheaper 12 AH with 200 crank amps for $30 from Wall mart may work in a 500 but yous 800 may NEED a 18AH(Amp Hour) with 250-300 crank amps,Wall mart also sells them but not for $30.
I recently bought one for my 700. Yes, they are expensive. However, the yuasa's that are oem are much better than any battery out there. Any competent mechanic will tell you not to substitute. Unless, you don't mind being stranded!
check thru the local interstate dealer they sell the correct battery also. and yes you will most likely pay 110 to 130 bucks for one of these. the twins take a differnt battey than any of the others
<div class="FTQUOTE"><begin quote>Originally posted by: TLC
My friend found out with his 660 Grizzly that the bigger bore ATVs with no decommpresion reguire a more exspensive battery , a cheaper 12 AH with 200 crank amps for $30 from Wall mart may work in a 500 but yous 800 may NEED a 18AH(Amp Hour) with 250-300 crank amps,Wall mart also sells them but not for $30.</end quote></div>
18Ah?? The 800 has an 30Ah.
Theres a place on outer Hammond St. in Bangor where I paid $99.00 for my sealed 30amp , maintenamce free battery. It is identical to the OEM one that came with the 800. The companies name is; TBA, phone # 207-262-1053. Tell them you saw their name on here and that it would be worth their while to sell you a replacement for that price. I DID have to strike a deal with them but it wasnt tooooo hard to do. Good luck!!!
<div class="FTQUOTE"><begin quote>Originally posted by: 02700sportsman
does anybody know a good place to get a battery for an 800. I went to polaris, and they want $130 for one. I thought that was a little high. Thanks for the help.</end quote></div>
I have been using Deka, batterys for a while now. i plan on replacing the 800 batt with one. I was shocked the first time i walked into my local polaris dealer and saw they carried them.
http://www.eastpenn-deka.com/default.aspx?pageid=510
