2003 Raptor 660 Reverse Problems
Old Jul 15, 2008 | 08:14 PM
houdinitattoo's Avatar
Default 2003 Raptor 660 Reverse Problems
Hello everyone,
I have two 2003 660 raptors. The first raptors reverse system works fine when I hold in clutch, turn the reverse **** on the front right fender and the gears shift into reverse and the reverse light comes on (only when turning the reverse switch **** which I'm assuming is the correct functioning way)
Now 2nd quad goes into reverse WITHOUT turning the reverse ****, i'm assuming this is NOT normal. When starting the quad and clutch held in I can press the gears shift down to reverse without turning the ****. Anyone have any ideas of the problem or solution or is this ok and will not cause any damage????
Thanks!
Mario
Old Jul 16, 2008 | 12:28 AM
maddog56's Avatar
There is a cable connected to the reverse switch, it needs to be adjusted so that the **** disengages when you release it.
Jmuddin284
Jan 19, 2026 07:16 AM
toonces
Oct 16, 2019 12:11 PM
ranvette
Jul 4, 2015 06:13 PM
yambam13
Jul 4, 2015 01:49 PM
bikedad3
Jul 2, 2015 02:15 AM
