500 Froeman won't move
Old Jul 16, 2008 | 09:49 AM
ochkev's Avatar
Default 500 Froeman won't move
Help Please. Manual shift 500 will not go. I can roll it, but when I put it in gear, forward or reverse, it doesn't move, just revs up. It shifts easily, but it doesn't "jump" when I put it in gear. Usually when one is put in first or reverse, it will move slightly. This doesn't. Putting it in 4X4 doesn't matter. Clutch or tranny problems????? Where is the clutch pack (rear side of engine, round cover???)
Old Jul 16, 2008 | 12:25 PM
HondaMechanic's Avatar
I would try to adjust the clutch first .. The clutches are under the front cover ..
Old Jul 16, 2008 | 01:20 PM
ochkev's Avatar
Thanks. I will try that today.
Old Jul 17, 2008 | 10:15 AM
ochkev's Avatar
I adjusted the clutch as you told me, and the front shaft started turning. I put in in 4X4 and the front axles started turning too. The rear shaft won't turn though. What should I do now?
lonerider856
Oct 13, 2023 03:45 PM
Dewhound
Apr 20, 2017 02:25 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
Elkaholic
Sep 6, 2015 02:44 PM
