NEED HELP BLEEDING REAR BRAKE
Old Jul 17, 2008 | 01:40 PM
miassmaro98's Avatar
Default NEED HELP BLEEDING REAR BRAKE
HEY GUYS MY REAR STOCK BRAKE LINE GOT DAMAGE ON THE TRAILS,SO I REPLACED WITH A NEW ONE.BUT I HAVE APROBLEM I DONT KNOW IF WATER OR DIRT MAY HAVE ENTER THE SYSTEM WHILE RIDING WITH THE DAMAGE LINE. BECUASE I TRY TO BLEED IT BY PUMPING BY THE BRAKE HANDLE AND NOTHING COMES OUT.OR IS THERE A CERTAIN WAY TO BLEED THE SYSTEM?
Old Jul 17, 2008 | 01:42 PM
Sontizzle's Avatar
unloosen the bleed vavle on the rear caliper while someone else is applying pressure to the rear brake. when u see fluid coming out have the other person completely push the brake lever down and when its completely down tighten the bleed valve back up. if you pump it your sucking air back into the line. hope that helps. its alot easier with 2 people doing it
Old Jul 17, 2008 | 02:06 PM
YOU LOST ME WITH THE while someone else is applying pressure to the rear brake?WHAT DID YOU MEAN BY THIS?
Old Jul 18, 2008 | 12:35 AM
Sontizzle's Avatar
have a buddy help you, its alot easier with 2 people. have your buddy pushing down on the brake while your bleeding the vavle
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Aug 14, 2015 05:59 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sandman2.0
Jul 21, 2015 09:03 AM
