Please share your 250r knowledge with a beginer!!!
Old Jan 26, 2001 | 02:47 PM
mx87trx's Avatar
I am 21 yrs old and new to the sport, having just started about a year ago on a new Blaster, but I have caught on fast and recently bought an race ready '87 250r with all the mods. The quad is great and I love it but I am planning on racing and it needs some tuning. I am having the 4 year old shocks rebuilt and working on the handling qualities, but I am filing plugs like a ****. Now I know that 2 strokes file plugs very often but this is rediculous. When I trail ride with friends I have to take 2 extra plugs with me and more often than not I end up using those 2 extras. I have tried to jet the bike a little better but with no luck, and it has no low or mid range power. I have a fmf fatty pipe and silencer and know that it is a high end pipe. I am also running a high comp. piston and a cool head with a 19 cc dome on it. I think my mixture might be too rich because the filed plugs are black. I am mixing 5 gallons with one container of oil(whatever that ratio is) and I am also mixing in a octane booster to get it above 100 octane. Please help a 250r virgin. If I cant get the bike tuned I cant race it. Any other ideas as to what might need adjusted, I will listen to anything at this point. Thanks for reading this book of mine.
Chris........'00 Blaster
'87 250r
Old Jan 26, 2001 | 04:00 PM
Monica81's Avatar
that is an odd problem if you can t find the answer within the fuel maybe you can be on x file's i also have a full race 4trx250r its an 86 i haven t had to mess with the plug since i got it 3 months ago it has an fmf fatty pipe cool head boysen reeds&cage k&n filter and ct 310 kit what kinda oil are you running ? motor oil lol
nah its gotta be jetting im pretty sure
86 atc&4trx250R's
Old Jan 26, 2001 | 05:36 PM
todd330r1's Avatar
you should be mixing at 32:1 ratio, you sound like your at 20:1, also, what size main jet do you have, you can drop the needle a position, and go up on the main jet, be very careful with the needle, it can lean it out and blow your motor though. what size and kind of carb do you have?
350R
Old Jan 26, 2001 | 06:45 PM
mxquadracing's Avatar
Try mixing 4 gallons to 1 pint of oil (equals 32:1). Is your air box lid off? If it's not, take it off. You'll get more air into the intake, then recheck your jetting.
Old Jan 26, 2001 | 07:08 PM
Dill's Avatar
last time I checked 4 gallons of fuel and a quart of oil wasn't 32:1 probably more like 16:1
Old Jan 26, 2001 | 07:50 PM
Racer18J's Avatar
He said 1 PINT, not one QUART ! Look before you leap.
Old Jan 26, 2001 | 08:32 PM
trapperb1's Avatar
If you're fouling plugs that often it most likely is A)jetting (try going down 1 size on the main jet), B) needle setting (try moving the clip on the needle), C) fuel mixture (I run Golden Spectro at 50:1 for dirt, 40:1 for sand), D) not enough air (hope you have an aftermarket air filter, if not, get one and open up the airbox), and E) you could be "lugging" the motor too much.
An FMF Fatty is a low-end/mid-range pipe (I have them on both R's in my garage).
Buy a Clymer's manual. It will help a lot.
Finally, there's a great site where someone that's a lot smarter than I am can help you and it's dedicated 100% to the greatest quad ever, the 250R. Go to http://pub20.ezboard.com/bhondatrx250r
Check it out! It's a very helpful forum.
Old Jan 26, 2001 | 09:03 PM
Dill's Avatar
LOL I coulda sworn it said quart.
my bad
Old Jan 26, 2001 | 09:30 PM
Dill,
I did say quart. My mistake. I didn't have my mind on what I was typing. I edited it.
Old Jan 26, 2001 | 10:07 PM
Z71's Avatar
Z71
go to http://pub20.ezboard.com/bhondatrx250r and sign up as a member.This is the best place I know of to learn about your 250r.The forum is about nothing but 250r's.I have an 86 250r w/ fmf fatty, rad valve , rev box , mild port but the rest is mostly stock. I trail ride and hill climb in the mountains of East TN.I run #9 plug and have never had one foul yet. I have been mixing oil at 20:1. with no problems.gonna try 32:1 next time out.Also get a good oil mixture measuring cup.Got mine at the Honda shop.They are worth thier weight.. in ounces..
