2001 polairs scrambler overheating..
Old Jul 19, 2008 | 11:33 AM
lowperformance's Avatar
Default 2001 polairs scrambler overheating..
JUST PICKED THIS UP AND I NOTICED IT OVERHEATING SO I CALLED THE LOCAL DEALER AND HE SAID A FAN TEMP RELAY BUT TO CHECK THE FAN SO WHEN I TRIED TO SPIN THE FAN IT WAS TIGHT??? DOES THIS MEEN THE FAN IS BAD??
DOES ANYONE HAVE ONE? OR WHERE CAN I GET A CHEAP ONE??
812-381-3261
Old Jul 20, 2008 | 02:41 PM
If fan blades tight to turn,then replacement probably necessary. First check where sensor at radiator bottom connects into fan harness,pull sensor end from harness connector,jump two wires at harness connector to see if fan works. If not fan motor bad. Saw some posts about auto parts electric fan being used.Check oem versus aftermarket if available,some of the other members should know. Good luck
Old Apr 2, 2013 | 05:59 PM
matt h's Avatar
Default please help
my 2001 polaris scrambler 500 4x4 keeps spitting coolant out the top of the over flow anyone have a clue as to why
Old Apr 2, 2013 | 06:13 PM
Jack the front end up and leave the radiator cap off while running to see if you have any trapped air. If the fan kicks on properly the level should go down and you can top off the radiator and replace the cap.May take a couple times for the fan to cycle on and off to remove any trapped air.Check also for any wet spots under the recoil area in case a water pump seal might be seeping also and loosing coolant. Low coolant levels can cause overheating.If after you do all this and it still spews into the coolant bottle you could have a defective radiator cap. 13psi caps can be found at most auto stores.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
35dodge
Sep 29, 2015 09:40 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
