honda foreman 450 es wont shift
Old Jul 20, 2008 | 12:24 AM
msch's Avatar
Default honda foreman 450 es wont shift
getting very little fire to switches on handle bars needing shifting wiring diagram so i can see were the main fire comes from. using my test light on the switches it barely burns the light of the test light so its not getting very good fire
Old Jul 20, 2008 | 01:40 AM
larrob44's Avatar
I have the same problem with the Rancher; every time it's a new electric shifter.
Get rid of it at a dealer and buy something else.
I'll never own another Honda.
Old Jul 20, 2008 | 01:48 AM
msch's Avatar
thanks but its my sons
I need to fix it for him
Old Jul 20, 2008 | 08:02 AM
HondaMechanic's Avatar
What year is the bike .. And just what is it doing..?
Old Jul 20, 2008 | 03:25 PM
msch's Avatar
wont shift at all with the buttons used a test light to see if there was power to the switches barely lite the lite real dim its a 1998 model
Old Jul 20, 2008 | 10:07 PM
Gimpster's Avatar
The system operates off 5 volts.
Main causes of them not shifting in that year is #1, the shift control motor being bad. #2, Gear position switch bad, #3, Shift angle sensor is bad
Your quad has no diagnosis features on the meter so if there is any issue with the shift system, it just will not work until the issue is resolved. No codes stored.
----- Gimpster -----
Old Sep 15, 2008 | 12:33 PM
300winchester's Avatar
Default honda foreman 450 es wont shift"></title><script src=
Did you get it fixed, if it wont shift at all then check the wiring to the crankshaft angle sensor, if that is off or bad it wont shift at all, my machine is intermittent, sometime I loose the speedometer and then shift all the way up to 5th just to find I have to shut off the machine and shift all the way down to restart, did you get yours fixed ???
greg74
Sep 10, 2019 03:03 PM
bigred20653
Aug 31, 2015 12:41 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
Jul 22, 2015 05:00 AM
