running rough after warm-up
Old Jul 20, 2008 | 03:45 PM
mikerich4's Avatar
Default running rough after warm-up
I'm hoping someone can help me with this problem. I have a '99 AC 300 4X4 and it runs rough and cuts out and backfires after reaching full operating temp. I have cleaned the carb twice, had a new regulator/rectifier installed, and ran about a half can of Sea Foam through it. The thing runs fine until it warms up. I think I read here a while back that valve adjustment will cause these symptoms. Anyone got a clue? It actually was idling extremely rough before the Sea Foam and now idle isn't a problem. Thanks, Mike
Old Jul 20, 2008 | 05:36 PM
tancat500's Avatar
Mine had a similar problem once and what i found was a hole in one of the vac. lines running from the fuel pump to the intake boot after the carb. Not real sure how yours is set up, but it is worth looking into. It was causing the fuel pump to operate very weak and also allowing air into the intake causing a very lean mixture. It to cut out and popped after warming up.
Old Jul 20, 2008 | 07:21 PM
mikerich4's Avatar
I'm not 100% sure, but I don't think I have a fuel pump. I believe it is just gravity flow from tank to carb??
SOLOLUCKY
Oct 4, 2024 09:09 PM
wannabe32
Jul 7, 2015 11:30 AM
gfl0224
Jun 27, 2015 06:52 PM
Polarisman1123
May 25, 2015 10:07 PM
Polarisman1123
May 25, 2015 10:03 PM
