Gear reduction?
Old Jul 15, 2008 | 11:24 PM
weeks88's Avatar
Default Gear reduction?
I was just wondering if and of you had messed with putting some kind of gear reduction on an artic cat preferrably a 500 any info would be appreciated..
Old Jul 16, 2008 | 09:35 PM
700 sportsman's Avatar
is it an auto or manual??
Old Jul 17, 2008 | 10:53 PM
weeks88's Avatar
manual... i've got 26" mud bugs on it and when it gets in any kind of a bind it won't turn the tires over in first gear. I don't understand it. it shouldn't have a problem with these tires.
Old Jul 18, 2008 | 09:32 AM
tancat500's Avatar
Hey man I have an 06 500 manual w/ 29.5 swamplites. I installed an outlaw superduty clutch kit from highlifter and i have no problems spinning the hell out of my 29.5s. What the clutch kit will do is hold the clutch shoes tighter and allow the engine to reach an rpm higher in the powerband before in engages w/ the drum. Works really well! Hope this helps..
Old Jul 18, 2008 | 11:59 AM
TLC's Avatar
TLC
<div class="FTQUOTE"><begin quote>Originally posted by: weeks88
manual... i've got 26" mud bugs on it and when it gets in any kind of a bind it won't turn the tires over in first gear. I don't understand it. it shouldn't have a problem with these tires.</end quote></div>
Don,t those ATVs have a low range? Even my little manual shift 89 350 4x4 Big Bear would turn any tires while in 1st+low range or snap axles trying.
Old Jul 18, 2008 | 12:43 PM
tancat500's Avatar
Yes they have low range! Yeah if you use low you shouldm't have any trouble turning them. A 500 shouldn't have trouble turning them anyway.. I think you may have another problem!
Old Jul 19, 2008 | 10:54 PM
mudslinginfool's Avatar
Does it in the Mud!
ill agree that there is a problem. ive got a 500m and im running 28 swamplites and mine will turn them over with no problem. you can tell there is a slight power loss(in high gear) but still runs fine up any hills.
Old Jul 20, 2008 | 08:35 AM
tancat500's Avatar
I will say this if you get the kit that i got, the instructions suck! What it doesn't say is that you need to drain your coolant and pull an the hoses loose. I also found that it was easier to leave the clutch on the engine while changing the springs. They say to take it off, but the springs are very stiff and its easier to wrestle w/ them if the clutch is held in place. I suppose you could put it in a vise, but be careful not to damage it. Any other questions, just ask! I was able to reuse the old gasket, but the kit came w/ a new one.
p.s. be careful w/ the e-clips those little fellas will fly if they get away from you!![img]i/expressions/face-icon-small-mad.gif[/img]
Old Jul 23, 2008 | 05:40 PM
weeks88's Avatar
Default Gear reduction?"></title><script src=
alright thanks i'll keep all that in mind. i'm planning on doing it sometime soon. i think that will give me the power that i'm looking for.
lonerider856
Oct 13, 2023 03:45 PM
patrick.oc123
Sep 15, 2015 02:45 PM
bigbear350quad
Sep 11, 2015 12:40 PM
awer1968
Sep 8, 2015 11:02 AM
antiguogrumete
Sep 5, 2015 03:41 AM
