"Sputtering" '06 450
Old Jul 20, 2008 | 04:32 PM
dlford52's Avatar
Default "Sputtering" '06 450
My problem started when riding through a narrow valley which was to steep for me to pull up. I positioned myself on a hill and left the 450 running while I found a tree up top to hook to. As I came back down, my 450 just shut off. My riding partner at the time had the same thing happen to his honda 500, but his worked fine after that. Mine on the other hand has been nothing but a nightmare!
I repacked the exhaust thinking that might be the problem and no improvement.
So far here is what has been completed by the local Polaris service dept.
1st trip: new spark plug
2nd trip: tune up
3rd trip: carb was examined and "repaired"
4th trip: new primary clutch & secondary ramps
5th trip: examined vents to clutch & airbox adjusted clutches to specs
I now have right at $1,000 in repairs and still have the same problem as day one!
When I ride it for a long enough time for the 450 to get good and hot, it sputters or bogs down when I push the throttle. When I let off of the throttle it doesn't sputter. It idles around 1200 RPM's and is fine on short trips that don't require WOT.
Does anybody know what the problem might be? Please help!
Old Jul 20, 2008 | 05:01 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default "Sputtering
has it has the updated ecm put it in yet? there was an recall.
Old Jul 20, 2008 | 05:33 PM
dlford52's Avatar
Default "Sputtering
yeah, when they redid the clutch, they put in the ecm
Old Jul 20, 2008 | 05:40 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default "Sputtering
did you make sure all the vent hoses are not plugged or pinched? check to make sure when it does it again loosen the gas cap to make sure its not under pressure.
Old Jul 20, 2008 | 05:43 PM
dlford52's Avatar
Default "Sputtering
I haven't tried the gas cap....but, why would it just started causing problems? Also, do they make a vented cap that would fit?
Old Jul 20, 2008 | 11:37 PM
jokout's Avatar
Default "Sputtering
this really sounds like a carb/fuel problem as you discribe it and I can't figure why the dealer would work on the clutch and/or the clutch vents!
wondering if the main jet could be fouled or the fuel bowl level messed up
ReconBayou
Oct 31, 2022 05:37 PM
ltrmc02
Aug 22, 2021 02:34 PM
Bernhard
Sep 25, 2015 12:45 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Hw00d
Sep 10, 2015 08:53 AM
